Hi all...so I have a 2011 bmw z4 e89 msport 30i. Its about time to change the engine oil. I bought 4 cans of Castrol oil (Engine Oil - Castrol Edge - 5W-30 Synthetic from RMeuropean and imprted them to Malta which is where I live. See the link below. I chose 5W-30 as recommended per the manual and obviously fully synthetic as required. Now the manual says that engine oil has to be approved by bmw and that it should meet LL-01 or LL-04 specifications. The oil that I bought meets the LL-01 criteria.
The question is this, on internet I have found that LL-04 oils should be used only in European countries and LL-01 oils should be used in non-European countries like U.S.A or Canada or Australia. Apparently this is because in European countries the sulfur content of the fuel is low and in non-European countries like U.S.A the sulfur content is very high. So, suffice to ask, why cant we use LL-01 oils in European countries? If European countries have low sulfur content fuels, why cant LL-01 oils be used just the same? If LL-01 oils can deal with high sulfur content fuels why can't LL-01 oils deal with low sulfur content fuels then?????? I am confused.
http://www.rmeuropean.com/Products/03037-MFG1135-V5124.aspx
