I WAS DRIVING THE M WHEN THE CAR STARTED VIBRATING ALL OVER. MECHANIC HAD A LOOK AN APPARENTLY THE BOLTS ON THE DRIVER'S SIDE HAD COME LOOSE, THE ENGINE MOVED DOWNWARDS, RESULTING IN THE SUMP TOUCHING THE SWAY BAR
NOW I DID A BIT OF A SEARCH ON THIS FORUM TOGETHER WITH ZPOST AND THE NET, AND APPARENTLY THIS IS A COMMON PROBLEM. MY CAR HAS 12,000 MILES ON THE CLOCK AND THE BOLTS CAME LOOSE. I FOUND A COPY OF THE BMW SIB (SI B 22 01 09) WHERE THEY CLAME THAT THE BOLTS CAN COME LOOSE DUE TO PROLONGED HEAT EXPOSURE TO THE RIGHT SIDE ENGINE MOUNT. I WENT TO THE BMW DEALER AND SHOWED HIM THIS SIB. SO FAR BMW INTERNATIONAL HAVE NOT RECOGNIZED THIS AS A PROBLEM AND ARE REFUSING TO COVER THE COST. I WAS OFFERED A SILLY 20% DISCOUNT BY THE LOCAL DEALER.
HAS ANYONE SUFFERED FROM THIS? DID THE DEALER COVER THE EXPENSE? IF NOT CHECK YOURS OUT PERIODICALLY. I THIONK I ALSO READ THAT THE BOLTS ON THE BACK ARBS TEND TO GET LOOSE. THESE ARE THINGS I DEFINITELY DID NOT EXPECT ON SUCH A CAR.
IF THEY STILL REFUSE TO RECOGNIZE THE SIB I MIGHT GET MY PERSONAL MECHANIC TO DO THE JOB AND THEN SUE THEM. PROBLEM IS THAT HE HAS TO START DISMANTLING TO KNOW HOW MUCH WORK IS INVOLVED. THE BOLTS ARE APPARENTLY VERY HARD TO GET TO WITHOUT REMOVING STEERING RACK ETC.
KERSTIEN
KERSTIEN
