Engine Light on - Z4M
adjenkins
Morning.
My engine light has been on for about a week, orange colour. Symptons when stationary are a rough idle.
When driving at low speed and a light throttle, there is sometimes a hestitatation on throttle pick up and some engine surging, car seems to miss a beat then picks up.
Less noticeable at cruising speed. Earlier the orange light came on about a month ago, I hoped it was just bad fuel. Symptons the same as now but the light went out by itself a few days later and driveability improved.
Will be heading to the dealers next week, just wondered is there anything I can check out myself or fix,such as cleaning sensors?
i stick my cash on it being a faulty coil pack which you can self diagnose, but best left to the dealers if its still under warranty?
Definitely not worth trying to fix yourself - either a coil or more likely i think an O2 sensor.
Faulty 'Coil on Plugs' (COP) are not normally an issue on the S54 engine. S54's DO have a higher than average issue with faulty O2 sensors.
Problem turned out to be both a coil & an O2 sensor, pre CAT. Car was in for nearly a week as they wired the sensor up incorrectly which started throwing out more error codes. Yikes! I had visions that everything electronic on the car would be changed and charged, before final identification of the problem.
Got a few other minor things sorted such as brake fluid changed, wipers, bill was £740. (discounted by £100 due to hassle). Think I might start going to a non BMW dealership for servicing work in future, the amount they charged for diagnosis, recoding etc just feels as though they are in right up to the elbow. :cry:
Out of interest, I have noticed the driver side wiper has a plastic trim on it, the passenger side does not. Would this be normal I can't recall prior to leaving it in a difference between either wiper.
Yeah. whipers are always different as one will have the wind catch - the other won't.
One word re Indy work, some swear by them but I see as many horror stories about never ending problems and no method of claiming against them. If you know a good one, that is of course different - but just getting one from the yellow pages .. :thumbsdown:
