MarshMA10 said:Was this thread ever solved? I discovered today my e89 35i has a similar symptom to the original post here.
- No issues doing hard driving up to about 5500rpm
- No issues doing lots of higher RPM pulls (but not to redline)
- No cold start issues
- No hot start issues
- No idling issues
- No issues starting the car if it hasn't been driven for 5/10 days.
- Historically has never had an issue doing a full redline pull then changing up a gear i.e. significant rev drop.
- Motorway 2nd gear pull to redline then letting it spin down still in second gear - so revs were high for a long time = EML came on, limp mode activated.
- Coasted to a safe spot, engine idling lumpy, i.e. revving itself from 1000-1500rpm.
- Switched engine off, switched back on again, all fine
- No issues for rest of drive/day.
Car has HPFP replaced and has had injectors done too, but they were probably 5-7 years ago (will check later).
Sounds like an ageing coil breaking down..what does the fault code reader say?
You of course as the owner of a 35i have a decent bmw specific fault code reader?
Fingers crossed it’s gone for good.
