Hi All.
Recently picked up a 2009 35i from a private buyer.
Full service history and 87k miles.
I have an EML issue I can’t figure out...
If I go through the gears in sport / comfort / manual everything is okay changing gear within 5500rpm.
If I use the kick down or manual so gear changes happen at the redline the following happens:
1st gear pulls all the way
2nd gear gets to close to 6000 rpm and power drops, EML comes on, if I come to a stop and turn the car off and back on the light has cleared and car runs normal.
If I replicate it in the same way, and roll to a stop a little slower, finding somewhere safe, the light will clear itself without a restart.
When the EML is on, the car runs and isles lumpy.
If I apply hard throttle in 2nd gear it will pull all the way, change to 3rd and the same thing happens as it approves 6000 rpm again.
I obviously can’t check this in all gears, but it only appears to happen when changing up and under hard acceleration for a prolonged period.
I plugged the car into a friends OBD reader and no fault codes appeared to be logged. Also when the EML comes on, the Idrive still says ‘no faults’.
Could someone suggest what this could be?
