Ive purchased a OBD lead and software but im having trouble getting it to work. I followed the instructions and the INPA software loads but everything i try to open suggests it cant find the file.
There are 2 things i noticed when i did the install.
1. Whist carrying out one of the first steps i had a DOS type screen pop up following the install of NSF Entpack1 disk 1 Setup. I noted that there were 2 warning messages..
Windows XP Version 6.2 Build 9200
Installing OBD driver...
SubKey 'SYSTEM\CurrentControlSet\Services\Serial' allready exist !
Reading values of the key ...
Value Type = 1 Expected = 1 Ok
Value Start = 3 Expected = 1 Warning
Value Group = Extended base Expected = Extended base Ok
Value ErrorControl = 0 Expected = 0 Ok
Value Tag = 21 Expected = 1 Warning
Value ForceFifoEnable = 1 Expected = 1 Ok
Value RxFIFO = 8 Expected = 8 Ok
Value TxFIFO = 8 Expected = 8 Ok
Value PermitShare = 0 Expected = 0 Ok
Value LogFifo = 0 Expected = 0 Ok
Warning! Some values have no standard data - May be there are problems !
Press any key to continue ...
Im not sure if they are causing an issue??
2. I then saw it asked me to set the COM port value from 2 to 4. Mine was set automatically at 3 so i changed it to 4 but it would not allow me to update the C:\Windows\OBD.IN file with the same value as it would not let me overwrite the original file.
Can anyone profile any help please??
