I'm in the UK so looking for UK supplier or EU. I'm replacing my rtabs rear trailing arm bushes on E89 23i . But after getting the car stripped and bush out (quite easy with correct tool set I used this kit : https://www.amazon.co.uk/dp/B0D6N3VN65 )
but unfortunately i had purchased the wrong bush to replace with so my options seem to be:
1. get oem bush and fit
2. get oem bush and limiters
3. get polybush
I was looking to just replace with poly bushes because if i go oem then i would want to get limiters also. The only place i've found for the limiters is here : https://www.hackengineering.co.uk/product/condor-speed-shop-rtab-limiter-kit-e36e46-inc-m3/ but again not sure if these will fit . and so the price of the limiters and the oem I thought poly would be the way to go.
But I can't find a set of poly bushes for E89 ? Are they the same as E85/6 ? I've read that E89 suspension is same as E85 mostly. I'm confused since I've seen that the PFR5-3608 from powerflex are recommended but not for the E89 ? There 's 2 types PFR5-3608H and PFR5-3608 .. and demon tweaks say they don't fit : https://www.demon-tweeks.com/uk/powerflex-pack-of-2-black-series-rear-trailing-arm-bushes-pfxpfr5-3608blk/
I check out polybush but there page doesn't list E89 https://www.polybush.co.uk/product-category/bmw/?v=8529f1b19d5e
So I'll give powerflex a call but has anyone fitted poly bush and what ones did you use ? What about the limiters, anyone know best supplier for these ?
Also, I get the preloading with the 8mm and the alignment of the bracket, but does the OEM bushing need to be inserted into the arm in a certain way? . does the split have to be oriented to a certain spot ? My old bushes are absolutely shot they fell apart when i pushed them out.
And finally, the brackets that came out are probably reusable with a bit of wire brushing and paint, seem solid but are quite corroded and flaked. I;m thinking i might just replace these as well since i need to order bushes anyway,
So either oem https://www.sytnerstevenagebmwparts.co.uk/p/132028401/33303411878.html, or
I could get epych which apparently are flat, so it;s like having a limiter, so i can fit oem bush without a limiter for same effect? ? Will polybush fit here ?
https://www.ebay.co.uk/itm/224902388659
Then there's this that look like the epych but are literally the half price for a pair ? is this dodgy
https://www.speedingparts.co.uk/p/model-specific/bmw-3230/bmw-e36/wheel-suspension/bmw-e36-e46-z4-rear-toe-adjustable-brackets.html
So any advice would be most welcome. poly bush which one, where to get in UK? Or oem bushes + limiters, where to get limiters ? and bracketes - do either poly or oem without limiters fit these flat sided brackets ?
many thanks
3. get polybush
many thanks
