Zed Baron said:Hope you get it sorted soon Sean![]()
RobbiZ4 said:I'd say, same story as the following on the other Z4 channel: :wink:
https://e89.zpost.com/forums/showthread.php?t=1843991
RobbiZ4 said:RobbiZ4 said:I'd say, same story as the following on the other Z4 channel: :wink:
Microswitch coupling lock on both sides of the hydraulic rams in the boot. Not the microswitches in the roof shell!
Ole gits rule said:Car back and sorted, microswitches was the issue and it was the ones Robbie said.
Covered under warranty apart from £50 which I am happy to pay as any issues and back to the garage.![]()
Ole gits rule said:Yep, was £35 for the switches so for £15 I am happy to let some else mess with it.
Especially when I collected it and the roof would not budge, took them 45mins of messing to get it to go, they had to move the switch.
I am not trying to be difficult, honestly, but I don't understand why that would be Robbie? As I understand it the bootlid ram microswitches are not functional until the last part of the bootlid (trunklid) cams pull the panel down and so momentarily make the switches. Why would this have a bearing on the whole process stopping randomly?RobbiZ4 said:One day it works fine, the other day the roof stops anywhere.
RobbiZ4 said:Ole gits rule said:Yep, was £35 for the switches so for £15 I am happy to let some else mess with it.
Congrats!
The problem is, that in most cases the faulty switch can't be measured with an ohm meter. The MS are not broken, but their timing doesn't fit anymore to the allowed tolerances.
Excellent to recognize with my
Y3 Roof Diagnostic System
https://z4-forum.com/forum/viewtopic.php?f=23&t=129048
Pondrew said:...so momentarily make the switches. Why would this have a bearing on the whole process stopping randomly?
Also, why would an ohm-meter be useful to determine the operation of a switch? A continuity tester, I can see.
RobbiZ4 said:Well, these microswitches are not only simple switches. They also carry 2 resistors internally, one in a row, the 2nd in parallel.
It's not a simple switch, there is always a current flow between the 2 wires of a microswitch. That's why you can diagnose it with an ohm meter: 570 ohms vs 2.770 ohms are the standard values.
The Cabrio Top Module (CTM) always checks the presence of all sensors as well as of all actors. If a wire is broken the CTM can identify it. If there is a short between 2 sensor wires , it can be detected as well. In addition, the 2 states OPEN as well as CLOSED.
LOL.Pondrew said:... and cannot find any resistors in there.
Ok, where's wally?Ole gits rule said:Are they are SMT (surface mount resistors), tiny squares on the board maybe?
Pondrew said:Ok, where's wally?Ole gits rule said:Are they are SMT (surface mount resistors), tiny squares on the board maybe?![]()
That's because they are not there (unless they're hiding)Ole gits rule said:Pondrew said:Ok, where's wally?Ole gits rule said:Are they are SMT (surface mount resistors), tiny squares on the board maybe?![]()
I cant see them either in your pic. thumbsup:
Pondrew said:That's because they are not there (unless they're hiding)Ole gits rule said:Pondrew said:Ok, where's wally?![]()
I cant see them either in your pic. thumbsup:![]()
