It certainly is, send me a PM and I can sort things out for youZikim said:Is this group buy still open? I would be interested if it is.
OK, two things here....scottp3000 said:Has anyone had the problem with google maps where it opens, but doesn’t actually display any visual map data? Is it just not getting a good enough data connection to my phone to download the map? Otherwise works really well![]()
AnubisZed said:OK, two things here....scottp3000 said:Has anyone had the problem with google maps where it opens, but doesn’t actually display any visual map data? Is it just not getting a good enough data connection to my phone to download the map? Otherwise works really well![]()
1) Your hotspot, does your phone have a decent signal?
2) (and more likely!!) Have you set the time zone of the screen to London? By default the time zone is China and if it is not changed your clock will be wrong on certain apps and things like Sat-Nav will default to china but you wont receive a map, thus a blank screen!
To set your time zone, go to "Settings", then down to "More Settings", then down to "System", then to "Date & Time" and set it as "GMT+01:00 British Summer Time". Hopefully your Google Maps will now work properly![]()
You're not a million miles away from me, I could fit it for you if you don't fancy doing it yourselfBeedub said:i cant look at this thread anymore, the envy levels are REAL.
AnubisZed said:You're not a million miles away from me, I could fit it for you if you don't fancy doing it yourselfBeedub said:i cant look at this thread anymore, the envy levels are REAL.Go on, you know you want to
Oh there is a e85 version coming out, it was supposed to be out now but it isn't just yet. It is cheaper than the e89 version, I've posted some info here... https://z4-forum.com/forum/viewtopic.php?f=2&t=114552Beedub said:AnubisZed said:You're not a million miles away from me, I could fit it for you if you don't fancy doing it yourselfBeedub said:i cant look at this thread anymore, the envy levels are REAL.Go on, you know you want to
this is the point..... i have an e85![]()
Jersey said:Evening all. I’ve read all 11 pages of this topic and also spoken with the folk at a-carnavi... and will probably be PMing you, Dave, at some stage when I get over the price...
However, I was wondering if anyone who started with an iDrive car and bought this unit had had a good enough look to see if a conversion to maintain the motorised screen would work. Obviously the manufacturer will have tried this but I’m wondering what the show-stopper was. Yes, it has the bulk around the back (but surely this could be in a separate box below where the screen mounts) and yes, it’s a bigger screen... but not wider than the original aperture so why can’t if be done? Too tall perhaps? Anyone had a good enough look to work it out? Regards, James
Certainly is, just send me a PM and we can sort the detailsLzar16 said:AnubisZed is the group buy still on very interested in purchasing the android and idrive controller![]()
Contact me at **removed**Lzar16 said:Hi AnubisZed I'm still a newbie tried to pm any otherway to get in contact? Lzar16![]()
This has been brought up a couple of times now so it's something I'm looking into. Hopefully I'll be producing an update video shortly with some further info.scottp3000 said:Sorted the previous sat nav issue - cheers!![]()
New one, does anyone else have the issue where the GPS takes about ten minutes to pick up current location? is there a setting for using current location with sygic to get you on the move? - sadly an IOS user, so Android and its quirks is all new![]()
