To clarify, most people think of the ignition barrel as the bit you put the key in.jarhead said:Engine doesn’t turn over at all, lights come on but no power.
I changed the starter motor because that’s what originally came to mind. In hindsight I shouldn’t have bothered but hey ho.
Thanks for the ignition barrel suggestion, I initially thought maybe it could be the immobiliser!
Take the lower steering wheel cowling off and you'll see it on the left side, with a plug connected to it.jarhead said:Really? That sounds straight forward however do you think it’s something a disabled pensioner can do or do I need a professional?
Well the one in the photo would probably do you.jarhead said:Thanks so much, that seems rather straightforward. I’m assuming I’ll have to get a replacement unit from the main dealership or can it be gotten from eurocarparts?
