Twin Turbo
ronk said:Twin Turbo said:However 28i will out handle an 35i, and if you have one modified - it will leave it for dust![]()
But then what happens when the 35i is modified![]()
Then it might JUST be able to keep up with me then
ronk said:That's oh so true - they are all limited to 155mph and swmbo squeals long before that !
Smartbear said:Busterboo said:So, my 35iS's factory 325bhp is acceptable, is it, Rob?![]()
It compensates for the additional 100kg of weight you're carrying![]()
Busterboo said:Smartbear said:Busterboo said:So, my 35iS's factory 325bhp is acceptable, is it, Rob?![]()
More than compensates, Rob. More than.![]()
Busterboo said:True, Rob, true. But not enough for a 4-potter to catch up.![]()
Zed Five said:Busterboo said:So, my 35iS's factory 325bhp is acceptable, is it, Rob?![]()
35iS is 335bhp stock.
however, the size of the brakes impresses. The front calipers are huge. It also has uprated springs and dampers, is 10mm lower than other E89s and has adaptive suspension. 8)
ronk said:Zed Five said:Busterboo said:So, my 35iS's factory 325bhp is acceptable, is it, Rob?![]()
Plenty fast enough for an old boy!
Twin Turbo said:There is a lot of good feedback,
Yes - test drive an 35i or 35is - as they sound sweet
Then - test drive a 28i if you can find one or an 20i for comparison.
As a daily driver a 28i has a considerable lower cost of ownership, and buy what is right for you.
ronk said:I think I can guess!
My Zed history is all 3.0l six, E85 , E89 now E89 35is. and I think it has been progression all the way.
I had every opportunity at the last change (sept '16) but couldnt find a reason on paper to go to a 2.0l four derivative and I didn't know anybody with a car to try - it's not the same as a dealer test drive is it ?
ronk said:A kind offer but I don't think I will be changing it now.
firebobby said:It all depends what you want from the car, is it a daily where better fuel economy is a factor and your happy pottering around in a four pot. Or is it a high days car that the fun factor is more important. My E85 3.0 will return low 40mpg on a run and i'm sure the larger engined E89 can sup fuel too. Your choiceI, but I know what I would go for![]()
