As I need to buy a new scanner, can you recommend one that does the Transport Mode Delete ?
Scanner 1.4 comes with cable. About £20 on eBay and simple to install on a laptopI am not sure if any scanners like autel can do transport delete but others will know
BMW scanner 1.4 will do it and you can buy this cheaply from Amazon but will need a dcan cable to connect the pc you load it onto
Same applies for ista and DIS
Scanner 1.4 IS BMW specificyou need a BMW scanner, not regular OBD reader, also have your E85 done the roof motor relocation? If not, do it. My motor was bath in water but after cleaning and some spining it work again.
