Further to my post yesterday I have a query which may also benefit others in future as well as myself should I need to make any more adjustments.
When you remove the footwell cover to access the steering column you have to disconnect three wires; one from the courtesy light and two from ' whatever it is', I'm not sure!!
Not wanting to have to put everything back until I'd tested the adjustment by driving the car, I carefully removed the two components from the cover and reattached the the three wires prior to turning on the ignition. Having read so many stories of dashboard warning lights and error codes I didn't want to trigger anything.
Is it necessary to reconnect the wires in this scenario or is it OK to leave them 'hanging' as it were?
Many thanks in advance
