Baris - Carphonics
Exciting, first person to have the new OEM user interface option.
markplant said:I thought you'd bailed on the ideapvr said:I have just received the kit, so will detail the installation steps of it.
Looking forward to how you find the kit![]()
pvr said:markplant said:I thought you'd bailed on the ideapvr said:I have just received the kit, so will detail the installation steps of it.
I did, but decided that it would make a nice R&D project for our gate automation system, which is also Linux based![]()
Brilliant and good luckpvr said:I have just received the kit, so will detail the installation steps of it.
Baris - Carphonics said:I finally received the z4 headunit, and it looks like it’s missing some buttons compared to the e46 headunit, so I’ve programmed in new ones.
I did SEL for back and 6 for menu. Menu is also on the steering wheel as the face. Both steering wheel and headunit has the controls for next and previous track. I just couldn’t show it, because if I start music, the video cuts off.
https://youtu.be/6Tjd7d_wvjU?si=qXvdeSkT4ILzSSuE
[youtube]https://youtu.be/6Tjd7d_wvjU?si=qXvdeSkT4ILzSSuE[/youtube]
Baris - Carphonics said:You would either need to tell me before hand or return the tv tuner back to me for the button re-assign.
Side note, you cannot use any button you want. The buttons still work in the background for the OEM system. This is why you have to leave it on the aux screen, which uses the least amount of buttons. So things like Menu and Tone cannot be used.
thecremeegg said:Baris if I have a Z4 with the nav screen, cd changer and no TV tuner, what do I need to buy from you? I assume the TV tuner kit and the bracket and perhaps a microphone?
thecremeegg said:If you have a CD changer can't you use that instead of running an aux? Or did you want to keep the changer?
thecremeegg said:Ah seems there are two options when ordering:
I'd go for that one instead I think
