Hi all, I did raise a thread on this previously, but thought it had gone away with a replacement battery, but the symptoms came back 2 months later :x
Here they are in detail:
Airbag light is on. Tried reading with code reader - Rarely works. When it does work its code 93E7 Undervoltage. Battery is less than 6 months old
Indicators don't work inside, but work perfect outside
After EXACTLY 2 minutes of driving or idling (timed and was exactly 2 mins), the dashboard display gets really dim and the dials light up, almost as if the headlights are on, but they aren't.
The CD player (original business CD) clock stops at the time the display goes dim (as above). It still registers the time, just the minutes / hours do not change
Only sidelights are working even with dial on full lights. Full beam / flash lights doesn’t work either
Battery drains over a week or so I have been taking negative wire off between uses
Central Locking works to unlock, but not to lock and boot button doesn't work although inside button for boot does
The doors no longer auto lock when above 10 mph
Took it to my usual mechanics, who couldn't get their reader to work either. They checked the carpets etc for wet but there was none.
It almost feels like some kind of transport mode, but probably isn't
Anyone else had anything similar?
Alternatively, anyone know of a good auto electrical place in or around the Bristol area?
Mark
Mark
