bigwinn said:Steering wheel- good as a spare while yours is off for the royals treatment £35 posted
replied budDFR said:Hi buddy,
Would like the headlights with the wires, all the sensors around the car and LCU.
Will PM
Edit:
Nope, PM denied. Stuck in outbox. Send me a PM or a reply when you can.
Cheers!
kis said:I don’t need it... but did you strip the engine out?
kis said:Go on then how much for the vanos?
Also do you still have the headlight connectors?
Negative and positive cables for the battery?
ryushe said:Would you still happen to have the interior 'dome' light module still available? If so, which type is it, how much, and would you be willing to ship to NL? Thanks!
Yeah, the light(s) above the interior rear view mirror. I seem to have a weird unit there with only one light...bigwinn said:Do you mean the 3 light cluster inlaid in the headlining?
ryushe said:Yeah, the light(s) above the interior rear view mirror. I seem to have a weird unit there with only one light...bigwinn said:Do you mean the 3 light cluster inlaid in the headlining?
Just so you know, I've done that swap and it is a simple plug and play, nothing else needed.bigwinn said:ryushe said:Yeah, the light(s) above the interior rear view mirror. I seem to have a weird unit there with only one light...bigwinn said:Do you mean the 3 light cluster inlaid in the headlining?
roger I know- yes you have the basic model
I've got a 3 light one happy to ship to NL- PM me
enuff_zed said:Just so you know, I've done that swap and it is a simple plug and play, nothing else needed.bigwinn said:ryushe said:Yeah, the light(s) above the interior rear view mirror. I seem to have a weird unit there with only one light...
That's interesting. The one I did was a pre-facelift so maybe there's the difference?jamie_z4 said:enuff_zed said:Just so you know, I've done that swap and it is a simple plug and play, nothing else needed.bigwinn said:roger I know- yes you have the basic model
That wasnt the case for me unfortunately, my facelift zed didn't like the map lighted interior light, none of them worked.
enuff_zed said:That's interesting. The one I did was a pre-facelift so maybe there's the difference?jamie_z4 said:enuff_zed said:Just so you know, I've done that swap and it is a simple plug and play, nothing else needed.
Interestingly though, I was led to believe that only applied to the earlier ones up to nearly the end of 2003?jamie_z4 said:enuff_zed said:That's interesting. The one I did was a pre-facelift so maybe there's the difference?jamie_z4 said:That wasnt the case for me unfortunately, my facelift zed didn't like the map lighted interior light, none of them worked.
Yeah I think with the pre FL, they put a lot more wiring in
ryushe said:Mine is a pre FL car so hopefully should 'just work', but good to know.
Seeing as the '03 and '04 cars basically are prewired for most options (or so I understand), can't imagine it being a big issue.
Will report back when it's here and hopefully fitted!
