now, call me pedantic, but,
The normal setup (no lights in dash) is DSC on, DTC off
When you press the DTC button and "DTC" appears in the dash, then DSC is ON and DTC is ON
Hold down the DTC button and you get DSC off and DTC off
DTC on is a bit halfway to off, in that it is supposed to prioritise forward traction, with a cost of less stabillity.
That's what my manual says anyway, only really talking about it use in snow.
bmw.com says it has 2 uses, snow and sport (although it seems a bit 4x4 oriented)
Dynamic Traction Control (DTC) allows for sports-style driving dynamics even when DSC is controlling stability and when wheel traction is higher.
Dynamic Traction Control (DTC) is a sub-function of the Dynamic Stability Control (DSC) system that can be turned on and off. DTC has two major uses: to regulate traction and to enable sports-style driving while providing active stability control.
If the front wheels are stuck in snow and cannot spin properly, this leads to slip on the rear wheels (when they spin faster than the front wheels, generally a sign that performance has been exceeded) and DSC acts to change engine output: the power needed for forward movement is reduced. Switching to DTC has a positive effect on this situation, as traction is improved without a loss of power.
When DTC is on, it helps the driver alleviate the situation enough for DSC's measures to become effective. The driver retains complete control over the vehicle.
