Having an issue with my drivers door not opening from the inside or the outside. I have a GM5 module that’s playing up but the issue only started once I changed the Bowden cable on the door handle carrier.
I have fixed the issue 3 times, only for it to reoccur within a few days. Thought I’d ask for some opinions before going through the hassle of removing the door card while the door is closed.
When the door card is removed everything looks to be in order mechanically. If I push down on the switch the Bowden cable is clipped on to within the door, whilst the Bowden cable is connected, the door will not open. When I unclip the cable from its nest and push the switch manually, the door opens which made me think perhaps I didn’t install it correctly. Do I need to pull the door handle while installing to keep the Bowden cable taut?
Any suggestions?
Any suggestions?
