Door Lighting Project
Sorry half. I'm now confused about what you have on your Zed what you are trying to get to work.
You can write in detail in Italian if you like and I can translate it
Grazie!
Io sulla mia Z4 ho solo la luce sopra lo specchio retrovisore.
Quando chiudo la portiera si spegne lentamente.
Voglio mettere le luci ai piedi, le luci anti pozzanghera e le luci alla maniglia esterna.
Il mio problema รจ : se collego tutto alla luce sopra lo specchio retrovisore.... quando guido di notte che mi serve la luce interna e la accendo, mi si accende anche la luce sulle maniglie esterne??
Ti ringrazio molto!
Talk about too cool for school, nice work. Has anyone used these, any good? They certainly have the Wow factor!
http://www.ebay.co.uk/itm/CAR-LED-Laser-Welcome-Projector-DOOR-LIGHTS-FOR-BMW-1-3-5-6-7-series-GT-lamp-/390684309873
I used these http://www.autoliongroup.en.alibaba.com/product/714106646-218329838/Genaration_2_led_car_door_logo_laser_projector_light.html sono buoni e non bisogna forare troppo :D
Dont suppose you would want to fit the puddle lights to my coupe cj10jeeper. Me and electrics and wiring do not mix well. I miss my puddle lights i had on my 1 er
The difficult is to pass the wires from the foot in the door. I have put the amber lights at the foot while riding, foot white when I turn on the rooflight, white with the switch in the glovebox, tray, amber and white in between the seats.
I miss the lights anti puddle but I do not know how to pass the wires to get in the door :cry:
hello i have everything i need to plug Internal Door handle lights... i want to be open when i turn on the lights. where i have to connect them? is it important to take out the door panel? thanks in advance
Hello, my Z4 is 2003 and had the wires to attach the lights to the wells of the feet that turn on with the dome light. You have to take those. You have to remove the panels under the steering wheel and under the glove compartment and find the two terminals. Search well because they are a bit hidden. Then, you must also remove the door panel if you want to put the lights.
How did you pass the wires in the doors?
thanks, but if i connect them there, when they will turn on?
I want to be opened when i turn the lights on! Im talking about the led inside the car At the door handle not the outside! Like the ashrey led light!
I did a long time ago ..... remember that if you buy the originals Bmw (63316902239) fit perfectly and connect them to the two wires of the keyglass as you know that is illuminated.
It 's simple. You just have to follow the instructions to remove the panel that is what is a little difficult.
Hi, I've read your post on Door lighting a few times now and having fitted my new footwell lights this last week my next stop is puddle lights and leds for the outer door handles (they do look classy). I've looked on eBay for single 12v LEDs but have only found ones rated at 3.3v which I assume would pop if given 12v.
I don't suppose after all this time you might find a link to the seller. I have a Maplins locally in Lincoln for the connector pins etc.
Many thanks,
Tony.
These?
http://www.ebay.co.uk/itm/3mm-5mm-10mm-Pre-Wired-LED-Ultra-Bright-Water-Clear-Bulb-9V-12V-Prewired-LED-/381597382921?var=&hash=item58d8f9f909:m:mxpyY_UXvItZOM5lclKqaug
Already have the required resistor as per the ones on first page.
Mike
