spazmochad
Has anyone had any luck updating their DME module for a M54 E85?
I have a 2003 3.0i auto which hasn't had a single module updated.
I've acquired a K-line cable, software and the latest SP-Daten but there's a couple of points I'm unsure of.
- I have a new battery and I'll likely charge it up to max out of the car before I start, but I keep hearing I need a constant 13-14v in order to update. Then I read people are just doing if off the battery. Professionals seem to use a 100a 12v battery charger which cost upwards of 600quid.
- When doing the DME update, do I need to follow it up with a transmission update straight away? I intend to pull to info for both the DME and trans before I start, I'm just unsure if they will be out of sync if I only do the DME.
I'm in Basingstoke if anyone is local
