Hey, I'm engine/airframes mate. Your first sentence lost me. :rofl:spazmochad said:It might do, depends if the MPC555 chip has died, the tool hooks up directly to it so just need that to be in working order. Could try reading it to take a backup first?
Have you looked at the harness and pins on the DME? Mine had oil pooled in the one of the connectors, think it wicked up from the oil sensor.
Bearing in mind I am very much mechanically biased could you please in simple terms how I would go down this route. Do I still need my vin coded to the replacement DME? How do I make it recognise my key?Martyn said:You can bench read the DME no problem, however if the DME isn't booting then you won't be able to access via WinKFP.
If the DME isn't booting because the flash is corrupt then BDM (background debug mode) using specialist hardware is the only way to communicate with the ECU.
It's unlikely the DME isnt booting due to corruption though so I'd check for water ingress, corroded pins etc.
If the DME is dead, just pick up a replacement from ebay, you can use the part numbers from RealOEM to find one that will suit.
https://www.realoem.com/bmw/enUS/showparts?id=BT52-EUR-08-2003-E85-BMW-Z4_30i&diagId=12_1240
Once you have the replacement you can use https://www.bimmertuningtools.com/product/ms45-quickflash/ to disable EWS and the car should fire straight up.
Btw, deleting EWS has no negative effects on the car or its security, it simply disables the check performed by the DME to check that it's 'paired' with it's original EWS module. A valid key etc is still required.
So................. apologies for doing this to death.................... I get another DME, tell it not to talk to the EWS module and pop it in. Simple as that? What about software versions? I have found many part numbers that can be retrospectively swapped with mine, so they should work straight away yes?Martyn said:The VIN in the ECU is just for reference. Your keys are paired with the EWS module and not the ECU.
Thank you. I have a source for one already.Martyn said:The software version is largely irrelevant, but for the sake of simplicity id pick one up that came from the same size engine.
bigwinn said:Interesting
Anyone got one of the bimmertools on here?
spazmochad said:bigwinn said:Interesting
I don't have anything outside of a BDM100 & the software for bench cloning like for like with a Windows XP laptop.
Cross-ref to this thread for more details please: https://z4-forum.com/forum/viewtopic.php?t=138958bigwinn said:Martyn said:You can bench read the DME no problem, however if the DME isn't booting then you won't be able to access via WinKFP.
Martyn
We got the new DME in the car and fired up the program- great
However I cant select the patch EWS box- I've asked the seller for support but he is better at one word answers than I am so not holding my breath...
Have you had this issue?
Martyn
I watched Stuart. Pretty sure he did exactly those steps but the check box remained greyed out.spazmochad said:bigwinn said:Martyn said:You can bench read the DME no problem, however if the DME isn't booting then you won't be able to access via WinKFP.
Martyn
Do you need to read the DME with the tool first, then load those files into the next bit before clicking delete EWS and writing the patched code back onto the DME?
enuff_zed said:I watched Stuart. Pretty sure he did exactly those steps but the check box remained greyed out.spazmochad said:bigwinn said:Martyn
Annoying as I'm convinced we're nearly there now.
Thanks for the offer.spazmochad said:If you get totally stuck you're welcome to send them both over and I'll clone them, hopefully Martyn comes back with some more knowledge of the tool and it's something simple.
