What else would generate a code for inlet camshaft Rob? I’m only aware of posn sensor. :?Smartbear said:That doesn’t say sensor, it says mechanical-maybe it’s deeper than a sensor. Swap them & see if the fault moves with the swap![]()
bigwinn said:I'd found a thread from an E46 330 where the vanos had been changed AFTER it had been laid up for a while, which threw this code: is it possible that its 'mechanical' issue is that the seals have dried up and now restrict movement?
Just looking for alternate answers as the solenoids werent at fault prior to the vanos swap, so why fail now? And this vanos unit was on the shelf off a car for a while?
Thoughts Rob, Chris?
Stuart
enuff_zed said:bigwinn said:I'd found a thread from an E46 330 where the vanos had been changed AFTER it had been laid up for a while, which threw this code: is it possible that its 'mechanical' issue is that the seals have dried up and now restrict movement?
Stuart
Yes I really should have mentioned Stuart who's been very quick to help every time I've asked. He pointed me in the right direction to google.
Chris_D said:What else would generate a code for inlet camshaft Rob? I’m only aware of posn sensor. :?Smartbear said:That doesn’t say sensor, it says mechanical-maybe it’s deeper than a sensor. Swap them & see if the fault moves with the swap![]()
Sludgepump said:Glad you got this sorted. I have just done my Vanos seals and everything seems fine (touch wood). I did the plank of wood
against the water pump technique to get the vanos off. Apart from that it was pretty straight forward. The little LH screws are a fiddle
to fit in such a small space.
Can you tell me what fault code reader you bought?
Father Christmas (Mrs Sludgepump) is asking me what I want for christmas!
Chris_D said:I’m also surprised that’s the only code your reader has thrown up!
I usually have a raft of false-positives at any given time.
You sure it doesn’t have an option for a ‘full’ or ‘deep’ scan?
enuff_zed said:Chris_D said:I’m also surprised that’s the only code your reader has thrown up!
Chris, I did do a specific scan on the engine side and this was all it gave me.
Yes, there is a function to scan the whole thing, but hey, it's running fine, I've just had a right faff fixing this and I'm currently doing the old fingers in ears, eyes tight shut and shouting la-la-la, theorising that what I don't know about can't give me sleepless nights![]()
Yup, took me ages to track down the problem to the fact I never checked the bloody thing in the first place!Smartbear said:Good detective work![]()
bigwinn said:So pleased you sorted it- good job!
Hope Mrs E_Z notices and appreciates the hard work!
Smartbear said:Chris_D said:What else would generate a code for inlet camshaft Rob? I’m only aware of posn sensor. :?Smartbear said:That doesn’t say sensor, it says mechanical-maybe it’s deeper than a sensor. Swap them & see if the fault moves with the swap![]()
I’m thinking that if the vanos isn’t moving then the inlet timing will be flagged up as wrong and the sensor itself could be fine.
Smartbear said:Smartbear said:Chris_D said:What else would generate a code for inlet camshaft Rob? I’m only aware of posn sensor. :?
So it was along these lines then![]()
