The two products are slightly different, and in the UK we have 'Castrol Edge Sport 10W-60' and 'Castrol Edge for BMW M Engines 10W-60' - it's the 2nd one that BMW says we should use in the S54. However, we can buy both from any reputable motor factors.Siener2 said:Thank you mmm-five.mmm-five said:You have to select your car marque & model in this database to get it to show you what they consider the correct oil.
There is one type that is only available from the stealers: "[Ultimate]: Castrol TWS Motorsport 10W-60 [Refer to Authorised Agents]"
Then there is a type that is available off the shelf: "[Premium]: Castrol Edge Sport 10W-60"
Would there be a real difference between the two, or is the one from the stealer merely expensive packaging? :scratchhead:
If you look at the chemical analysis of both products you will see a small difference in make up of the oils, and whether that's important or not I'll leave to you to decide.
'Castrol Edge for BMW M Engines 10W-60' used to be called 'Castrol TWS Motorsport' but they changed it for some reason.
