I'm not sure if your box is different to mine but if it says S1 S2 etc then you've enabled manual shifting - it should say SD.
Ignore that - your box is different to mine!
PixelPeepZ4 said:So to clarify - this is all in auto, no manual override..
driving along, car in sport, gearbox in sport (it shows S1, S2 etc on the dash) then flooring it doesn't give me (or doesn't seem to give me) as much acceleration as when the gearbox is Not in sport.
Rockhopper said:Mine is the older five speed box but I nearly always drive it in SD (pushed over to the left). If I leave it in D then it feels sluggish and too eager to change up. SD makes it change down one or two gears and it feels a whole lot more responsive. If I press the sport button as well I find it quite difficult to get the car moving without smacking my head against the head rest! I tend to set off then press S as it’s just smoother like that. I don’t like the extra weight it gives the steering though so I don’t use it that often.
YES it certainly does despite what people might tell you, this is noticeable over long trips especially. After driving around 340 miles sedately to this years national meet my DCT in normal was changing so gently you could hardly tell and into 7th at just over 40mph! It was a delight (but boring). After Sundays madness it was a completely different experience, not changing gear till around 3100rpm!!!. Again after the return trip it was nice, gentle and quiet.Pbondar said:Does the DCT box 'learn' adaptations like the ZF boxes?
If so does a previous owner's 'bimbling' contribute to a sluggish response?
Would a re-set have any benefit?
enuff_zed said:OK, off at a bit of a tangent, but this does relate to wifey's 2.5i auto............... what exactly is the difference between pushing it over to the left and leaving it there, or pushing the sport button? Both actions show SD on the dash. I thought pushing it over just gave you the option to manually control it, but essentially it was still in Sport?
Rockhopper said:enuff_zed said:OK, off at a bit of a tangent, but this does relate to wifey's 2.5i auto............... what exactly is the difference between pushing it over to the left and leaving it there, or pushing the sport button? Both actions show SD on the dash. I thought pushing it over just gave you the option to manually control it, but essentially it was still in Sport?
Pushing the sport button does the same as pushing the gear lever to the left - but - it also makes the throttle more responsive (so you have to press it less to get the same amount of go - it doesn't give you more power) and it stiffens up the steering (which i don't like).
I shall relay that to SWMBO and see if she even cares :roll:Rockhopper said:Yes, thats what seems to happen.
mcbutler said:YES it certainly does despite what people might tell you, this is noticeable over long trips especially. After driving around 340 miles sedately to this years national meet my DCT in normal was changing so gently you could hardly tell and into 7th at just over 40mph! It was a delight (but boring). After Sundays madness it was a completely different experience, not changing gear till around 3100rpm!!!. Again after the return trip it was nice, gentle and quiet.Pbondar said:Does the DCT box 'learn' adaptations like the ZF boxes?
I dont buy that matey, 'facts' or no 'facts' the difference was distinct and undeniable.R.E92 said:mcbutler said:YES it certainly does despite what people might tell you, this is noticeable over long trips especially. After driving around 340 miles sedately to this years national meet my DCT in normal was changing so gently you could hardly tell and into 7th at just over 40mph! It was a delight (but boring). After Sundays madness it was a completely different experience, not changing gear till around 3100rpm!!!. Again after the return trip it was nice, gentle and quiet.Pbondar said:Does the DCT box 'learn' adaptations like the ZF boxes?
I hate to bring facts to the discussion but I have a copy of all the shift points pulled straight out of the code running in the DCT and they are set in stone (ROM). There's 21 individual tables but only about 10 are actually used, they don't change depending on how fast you drove last Sunday.
Does this refer to the DCT or the auto box Peter?Pbondar said:Copy of what an E89 BMW technical document says..
mcbutler said:Does this refer to the DCT or the auto box Peter?Pbondar said:Copy of what an E89 BMW technical document says..
