The brushed aluminium part? Remove the airvents, 2 clips one in the middle at the top of each vent, unclip them with a pair of small screwdrivers and pull the vents out, then 2 screws for the radio, I think 2 more holding the ally trim on behind the vents, the rest is held on by push clips that will release as you pull the trim forward, apart from one at the door end, that has a pin going through it that you have to remove from the back, gotta remove the air vent for that, one screw under a little black cover at the top, one under the cup holder/blank where the cupholder would be if you don't have one.
