B21 said:Argyll Andy said:B21 said:I think I’ll go for the Garmin mini initially then either add a second mini or one of the other Garmin units depending on how the mounts work out..
I appreciate that compared to a headrest mounted or bumper mounted solution it will be inferior but probably better than nothing…
I’ll order the mini now and see what gives..![]()
If you installed two individual units of these do you know if you’d be able to wire them both through the one voltage monitor/regulator unit that cuts the power to save the battery from going too low?
Yes![]()
That’s unusually succinct..![]()
Good
Yes, it is
