rayz4 said:Hi B21, yes you could mount the cam anywhere you like.
B21 said:rayz4 said:Some pics from yesterday’s dash cam install. Cost all inclusive, nothing else to pay. Turns off when ignition off. There is a kit available to trigger recording if the car disturbed while away from the car but I didn’t take that option. Battery won’t go flat while laid up for longer periods, I use battery conditioner. Wiring went along the header rail and down offside a pillar to the fuse board. All very neat and tidy. Very happy to pay the money for the install, I’m retired now old, lazy and quite well off.
Out of interest could you mount that version so its pointing rearward ie to act as a rear facing camera?
Argyll Andy said:B21 said:rayz4 said:Some pics from yesterday’s dash cam install. Cost all inclusive, nothing else to pay. Turns off when ignition off. There is a kit available to trigger recording if the car disturbed while away from the car but I didn’t take that option. Battery won’t go flat while laid up for longer periods, I use battery conditioner. Wiring went along the header rail and down offside a pillar to the fuse board. All very neat and tidy. Very happy to pay the money for the install, I’m retired now old, lazy and quite well off.
Peter, do you think that existing mount could be adapted/made to fit in/on the roll hoop since it’s so small?
B21 said:Argyll Andy said:B21 said:Out of interest could you mount that version so its pointing rearward ie to act as a rear facing camera?
Hi, I’m not sure hence my questions..the mini garmin is very compact..I hate those big things hanging down with a distracting screen…
I can’t work out whether the forward facing camera mount can simple swivel backwards..
Awaiting Ray comments …but given that the two cameras could be networked looks a cute idea..
The issue with a rear facing camera mounted on the hoop is that most are not water resistant so it’s an issue for us hard core top down motoring chaps..![]()
Argyll Andy said:B21 said:Argyll Andy said:Peter, do you think that existing mount could be adapted/made to fit in/on the roll hoop since it’s so small?
I know the rear facing element of this covers rear passengers etc but I’m wondering if due to the small cabin size in the Z4 if the rear facing one would “catch” the images through the rear window when the top is up or is clear enough for the same when the roof is down.
https://www.halfords.com/technology/dash-cams/garmin-tandem-dash-cam-366398.html
Yes the waterproofness may be an issue for us up here. Suppose we’d just need to maintain enough speed to ensure the water blows over the car :lol:
rayz4 said:Hi ORI, I once left my 35is for three weeks at Heathrow airport while on holiday with no battery drain problems.
ori said:I’m close to pushing the button on a thinkware f800 pro. RAC do it with the hardwire into obd port for install of £79. Will see if I can get it cheaper.
Argyll Andy said:ori said:I’m close to pushing the button on a thinkware f800 pro. RAC do it with the hardwire into obd port for install of £79. Will see if I can get it cheaper.
[ref]ori[/ref], any particular reason for that one? Also what’s the advantage of the OBD install and does that have the battery protector built in?
B21 said:Argyll Andy said:B21 said:Argyll Andy said:Peter, do you think that existing mount could be adapted/made to fit in/on the roll hoop since it’s so small?
Suck it and see?
I don't think there's a perfect solution...from the rear I'm more interested in capturing the rear enders that then push you into someone in front..hopefuly there would be enough resolution plus sound effects to determine such events?
B21 said:I think I’ll go for the Garmin mini initially then either add a second mini or one of the other Garmin units depending on how the mounts work out..
I appreciate that compared to a headrest mounted or bumper mounted solution it will be inferior but probably better than nothing…
I’ll order the mini now and see what gives..![]()
Argyll Andy said:B21 said:I think I’ll go for the Garmin mini initially then either add a second mini or one of the other Garmin units depending on how the mounts work out..
If you installed two individual units of these do you know if you’d be able to wire them both through the one voltage monitor/regulator unit that cuts the power to save the battery from going too low?
