Unfortunately I have a coolant leak at the rear of the engine. The leak is dripping onto the exhaust manifold. It is dripping directly off of the engine next to a plastic plate bolted to the back of the engine.
The car is not overheating and runs ok. Although the heater is now only blowing out cold air.. It also seems to lose coolant at a slightly faster rate when I first top it up and then levels out.
Any idea’s what this might be?
I am obviously praying it is not the head gasket. Usually it would overheat if it was?!
I have read about ‘freeze plugs’ or ‘core plugs’ although I cannot find much about them to the point I’m not sure they exist! Incidentally, the issue first arose after we have had this bitterly cold weather.
Any idea’s?!
Any idea’s?!
