Hi everyone,
Yep, now I'm using my car occasionally vs every day it seems to have more problems than it used to... grrr.
So for the last year or so the coolant seems to go down a slight bit but I top it up and it's fine. I think I've put in about 250ml in the last 18 months.
But on Friday the light came on in the car, so I refilled it up to the top when cold (I'd just bobbed out for a local curry hehe, so it was cold any way). Since then I've done about 25 miles and now tonight the light has come on again and it seems to have turned into a bigger leak.
I had a look under the bonnet and there is coolant leaking off a pipe just under the VANOS area. It looks like the water pump sits up there, and a few plastic solid pipes run near there, with rubbers then running off those with bayonet type attachments.
It seems to be simply leaking from a bayonet connection? Is that a common problem? A common failure point?
It looks quite hard to get to though which could complicate matters, but mainly I'm just checking if this is a common problem for it to fail, and if it's an easy fix?
I'll think I'll be taking it to a garage for the fix unless it's literally a replacement pipe and a 30min DIY job to replace pipes up in that area...
This car this last month hehe... seems to be emptying my bank account nicely hehe.
Many thanks for any help!
Dave
Dave
