rsutoratosu
I been spraying rust penetrator for over a week now. Different types also, the bolt that goes to the pump from the motor has corrode away and stuck. Since the motor has no thread on it, I should be able to cut the top of the bolt off and remove the old motor and extract the remaining thread on the pump side. So issue is to find a replacement bolt since bmw only sells the entire unit. Anyone might know the bolt or substitute bolt I can use ?
