Chippie said:strugglinauthor said:enuff_zed said:Sport settings are still available on non adaptive cars.
If you’re not sure then you need to ask someone to check the shocks
Thanks. Confirms what I found online. Think I'll ask someone to pop it up on the ramp and say for sure.
I wonder if there's somewhere online where I can enter my reg or VIN and get confirmation...
If you look through the Front wheel, if you can see a lug on the damper, just above the brake disc, then you have adaptive suspension
You should also be able to see a similar lug on the rear looking underneath the back behind the rear wheel.
He’s had a Vanos check..therefore it’s not a N54 or N20 therefore it’s not adaptive
