deltasierra
Hi I have code 2A98 causing a misfire on a 07 2.5litre Z4, it is vanos related where do I start trouble shooting this fault
Just to confirm, the link shows a solenoid and the parts list says Qty 2.colb said:Previous post on this code here https://z4-forum.com/forum/viewtopic.php?p=1854461
Suggestion is to strip and clean the solonoids and swop them over to see if code moves to ID which one is bad however the 2.5 only has one solonoid shown here on realoem parts site so just clean that one. https://www.realoem.com/bmw/enUS/showparts?id=BT32-EUR-07-2003-E85-BMW-Z4_25i&diagId=11_2170
As always with fault finding I would advocate changing one thing at a time, or else you'll get lost and not know what has made the changes.deltasierra said:Is there anything else that needs checking or replacing on the engine while I have the spanners out.
Good stuff. Thanks for the feedback too.deltasierra said:Removed and cleaned both solenoids this morning, fiddly but straightforward, did a 30 min road test and all OK,
