lakeeriesailor
I will try to post a picture a bit later.
pvr said:Just to note that this issue was resolved in the facelift model.
Ewazix said:pvr said:Just to note that this issue was resolved in the facelift model.
Not according to some members :? several post-facelift owners have reported the same wet motor problems despite the improved sealing of the housing - someone even suggested the sealing was actually keeping more water inside the housing once the thing was flooded, so drain cleaning is still going to be worthwhile.
Such a c**ap design :thumbsdown:
pvr said:Ewazix said:pvr said:Just to note that this issue was resolved in the facelift model.
I posted that in 2009 though ...
aquazi said:I cleaned my drains for the first time today... Complely blocked full of mud like substance![]()
I removed the plugs and shoved a straw up there until they were clearer... But not 100%
Spent ages trying to unscrew the plugs then realised they just pull out![]()
Danderton said:The PDF won't load for me. Can anyone upload it?
Are you going in from the top or bottom? There is some sort of sleeve restricting the tube near the top when approached from the bottom. It can take several pokes to get past it, which is why in part the bottle brush idea is great. The bristles help keep the wire from snagging on the restriction. From the top I would think what you see is what you get. You can just barely make it out on the right side with a torch, the left is completely hidden.SteveD said:I am not sure if there is some sort off inner rubber tube that may be blocking things?
