Changed knob and now gearstick turns!! Help.
Z4 COUPSTER
 Bridgend South Wales
As per what have you done to car today. Tried pulling and twisting (in the end I butchered the old one)
And now the gear stick will turn.
Have I damaged something or do I just twist back?
D
Broken maybe, but hell of a difference on the gear change. Can't thank Buckley 06 enough.
Deffo get one peeps!
I have heard of this occasionally happening if to much force has been applied, it has been covered before if you do a search. I think that you may have damaged or broken something :cry: so I think some investigation work is required. Hope you get it sorted quickly.
https://www.realoem.com/bmw/enUS/showparts?id=BU52-EUR-01-2007-E85-BMW-Z4_30si&diagId=25_0343
Thanks Swiftly, I can't fond anything but ill keep looking. Gear change is fine, if anything Id say that top bearing is fubared.
D
The gear-knob on my current Z4 used to twist a bit.
Anyway I swapped it for a ZHP last year and when I fitted that I gave it a gentle whack and no twisting any more! :)
So I think it must have seated better - it's got to be worth a try OP. :thumbsup:
