kinger said:I followed the following,
It will be in 2 modules CAS and FRM.
Changes you need to make in CAS:
You will need to change following options:
Comfort folding/unfolding for sideview mirrors
• active <-- This one
• not active
When holding the lock/unlock button on the remote the sideview mirrors automatically fold/unfold. To activate this function please activate ‘Comfort folding/unfolding for sideview mirrors’ in the ‘FRM’ module. Also activate ‘Comfort open using remote’ and ‘Comfort close using remote’ in this module. (CAS)
Comfort closing delay (mirrors)
• 0.0s <-- I selected this one
• 0.5s
• 1.5s
General delay for comfort closing. If ‘0.0s’ is set, mirrors fold immediately when car is locked. (CAS)
and
Do following changes in FRM:
• not active
This function requires an installed LIN-Bus (usually installed with mirror heating)nWhen holding the lock/unlock button on the remote the sideview mirrors automatically fold/unfold. May need additional coding of the ‘CAS’ module. (FRM)
Hope that helps
Mike
No, of course John, totally unwise to do it at speeds above say 10mph on a bumpy road but handy enough that you can pull away slowly from a traffic light mid-drop/raise and avoid the motorists behind you giving the making a sausage gesture. :lol:john-e89 said:Chris_D said:Lovin Carly. So easy to use.
Done a few things on mine but by far the most useful has been to code in the ability to raise/lower the roof while moving as I got caught out a couple of times at the lights, usually coming off the motorway. lol
edit. probably unlikely but if anyone here is around the Vleuten, Utrecht area I'll let you use mine for a few beer tokens....
:wink:
Is that wise Chris? The E85 roof wasn't designed to lower or raise whilst travelling unlike the E89 roof. You could well sprain the mechanism I would have thought. :?
kinger said:The chirp confirmation is in the Alarm module , you have to activate both of the 'Audible' options
Mike
I coded/activated the audible unlock on my E85 but it's so loud that people look over and i then feel a bit self-conscious, sort of like 'i got your attention, now watch this old fart struggle to get into his roadster' hahahWrs said:kinger said:1) Folding mirrors on open and close
4) Added a 'audible 'Chirp' to door looking and unlocking
I bought the Carly Pro IOS app and would like to code my car for the above 2 features.
Can you please share the steps in the settings to follow Mike? When I attempted the folding mirrors setting I could only get it to work if I press the lock button twice.![]()
Oh really? Well mine lowered no problem when backing into the garage of the seller of the hardtop i bought recently... Ergo, that must mean it's been coded succesfully, no?buzyg said:Marlon said:I'm liking Carly very much![]()
(I'd like to code mine to raise and lower on the move Chris but you're not exactly local)
Standard E85 can't be coded for that, unless yours is modded.![]()
Hmm, maybe i thought i'd coded that successfully then, when it was there as a facility all along. Have to wait til next year to verify it. Hey ho.willgill said:e85 lowers at very low speed, very definitely not at 30mph, think it chucks up a red light on the dash above 5 or maybe 10mph
Check the website pastry, it's all there. Very handy ap for fiddling about with ur zed's brain....Pastry said:What actually is Carly? I see that it is an App or part of an App, how does it connect to the car?
Is it expensive? I'm picking up a 2010 E89 this week and all the things you described earlier I assume can't be set with Idrive alone? (Not had idrive before) it doesn't have comfort access so will carly allow the roof to be closed via the key remote or do I need smarttop for that?kinger said:Has a wifi enabled dongle that plugs into the OBD2 socket
The website is great for indicating what the possibilities are for each model.....Pastry said:Is it expensive? I'm picking up a 2010 E89 this week and all the things you described earlier I assume can't be set with Idrive alone? (Not had idrive before) it doesn't have comfort access so will carly allow the roof to be closed via the key remote or do I need smarttop for that?kinger said:Has a wifi enabled dongle that plugs into the OBD2 socket
Paul
Paul
U could always try it out by buying a cheapo 5 quid dongle from ebay and the free lite version of the app. Wont let u code or see live parameters this way but u can certainly see fault codes diagnosed and get a feel for the interface....Smartbear said:Pastry said:Is it expensive? I'm picking up a 2010 E89 this week and all the things you described earlier I assume can't be set with Idrive alone? (Not had idrive before) it doesn't have comfort access so will carly allow the roof to be closed via the key remote or do I need smarttop for that?kinger said:Has a wifi enabled dongle that plugs into the OBD2 socket
Paul
I'm wrestling with myself over buying this at the moment, lets concur before we buy 2 of them :violent1:
It would be easy if I had a little more faith Chris, if I remember right you spend more time pushing yours than driving itChris_D said:But a good investment imo. Not the cheapest method for diagnostics and coding but certainly one of the easiest and convenient requiring only ur phone/tablet and a dongle....
Actually just buy it paul. I'm making an executive decision for you. That's easy isnt it?![]()
