keving1 said:If the spring is M Sport and car was sitting at the correct ride height before dampers & springs were changed, then it can only be the following-
- Spring is not located properly in strut, there is a set location at top and bottom of the strut that the spring sit
- Strut is not fully pushed down into hub
- The strut is not correctly located at the top going into the car body
- The strut is incorrect, there are different struts for different models - I don't know if this would make a difference to the height but worth checking?
Thank you some very valid points... all possible except last pint - shock absorbers - strut dos not influence car height 8)
