Well, i have another post where i explained that i changed from adaptive suspension to non adaptive ( due to cost of adaptive shock absorbers just being rip off).
So i changed 4 coil springs and 4 absorbers, i put Sachs . All good except that front keep sitting some 15mm higher. This is driving me mad!!!
First time when garage did job back in the UK they did mistake as they have instated M springs on rear and standard on front so car was sitting high on front as M suspension is 10mm less.
After few weeks we realized this is the reason for car sitting high, so they sent me new springs by post as i took the car across Europe to Barcelona.
Yesterday we had new "correct" spring installed and to my horror car keeps sitting high again. M suspension Z4 E89 35i with 19" rims front needs to be 621 my one is : driver side 631 and passenger 635mm. Now this was instated yesterday, and i did some 50km but after measuring its keeps being the same.
Standard non M height is 631mm so this made me believe that they again sent me wrong springs, but as i also purchased M springs i compared and measured with the one they sent me and spring was aprox 315mm and thats M spring height.
So what are we missing, why is front still stubborn sitting high? i read somewhere that if control arms were tightened while suspension was hanging, causing both the upper and lower control arm bushings to be pre-loaded could this account for some of the increased height? Can wrong installation process be at fault?
I checked only difference between M and standard suspension is the springs being 10mm lower, so i think we have all parts correct.
Oh and to add little extra, rear end passenger side sit correctly at 609mm but driver side sit 600mm so i added yesterday 10mm spring pad I as car has standard 5mm at rear) and now i got this extra 5mm...i think need to measure the rear...just been so focused on the front
