Bulb warning light - Latest update
Mangozac said:
Marlon said:
I can't get to them - its one of those ridiculous bulb sockets that are virtually inaccessible, I'm having to work blind using a long screwdriver just to get the bulb in and out.
Hey Marlon, did you manage to sort this one out? I've got the same problem but the failed indicator bulb is intermittent. I've replaced the bulb and bent out the contacts on the bulb holder but to no avail. Next step will be to pull the bumper and headlight off and check all of the contacts...
I did manage to replace the bulb 'blind' using a long screw driver - pitta if you have to remove the bumper!
You could just code out car to stop checking when cold and warm so no warning light , navcoder software does it "front blinkers" & "rear blinkers"
sorry for the poor pic.
I feel like that would be way easier just removing the bumper!
Fair suggestion, but I'd rather not disable the fault checking. It goes have a legitimate function ;)
