I have searched and read many if not all of the threads on here regarding this, and still I have issues.
1) The car has BT fitted, has been working fine on 3GS for over a year.
2) New iPhone4S to be paired works OK with the E60, so no issues with phone it would suggest.
3) I have no paring button in the centre console as I fitted a 3GS cradle and snap-in last year. The original cradle had the pairing button, hence how I originally paired the 3GS iirc.
4) Have tried many permutations of the Ignition off, hold down the R/T or Call buttons on steering wheel for 3 seconds and releasing after turning key to position 1, 2 etc.
5) If I press the R/T button I get "No Phone" displayed, this is all.
Any ideas how to initiate the Pairing process given the above information? The manual is not useful as I have "no pairing button" as originally stated. I have read that on the E46 there is an option to short some pins etc, not sure this is an ideal method.
Anyone got a procedure to unpair, maybe this is required? I have tried unpairing by the various methods, but maybe I am missing a trick somewhere as it seems others have had success. A detailed procedure would be appreciated given my particular configuration, No Nav, no pairing button and Business CD.
I wouldn't normally consider myself as a "Muppet" when it comes to technology, however in this instance the case for the prosecution appears to be gaining momentum, TIA.
UPDATE: Seems I am a Muppet! It couldn't really be easier. No need for 3 seconds this and 3 seconds that, turn key to here and turn to there etc.
The release button with the bluetooth logo on "IS" the Pairing button on the new cradles! Simply hold this down, put key in ignition and start the car and release button. BT Pairing then initiates! Thanks for the replies.....
