spazmochad
Has anyone had a drivers side B pillar module go bad? (2003 3.0i)
Mine is showing an error for the BST battery monitoring, 98F2. I've checked the cabling and can't see a short. I've tried a 2.2ohm resistor on the yellow connector by the battery but it doesn't seem to show any reading.
Detonation Circuit 6 is showing Resistor of detonation pill after last power on reset still not measured.
Pin 9 and 10 on the module show an increasing resistance up to 10k ohm like a cap is being charged.
Not sure what else to try. The small monitoring unit for the mat on the other module went bad so I've coded that out. This airbag light is going to write off the car.
. The module doesn't seem to be reading anything for the BST. In INPA detonation circuit 6 is reading nothing during startup. DIS is saying to replace the module.
