Sim_Simma said:
I have taken a cv joint apart and put it back together, I'm quite sure 90% or independent garages would leave the driveshaft on while fitting springs. If someone comes back from getting springs fitted with a broken cv then I'll eat my words. But I doubt that will happen.
As I've said: I've personally broken a (bmw) drive shaft with muscle power/body weight. And then again: it is the procedure according to TIS.
I'm not saying you'll break the drive shaft every time (same goes for the stabilizer links, thats the same issue), but there is a risk (especially with the stabilizer disconnected, the cv joint ballcage will get the full load of the force). And in case of the drive shafts, that is a 400gpb risk (per side). I leave it up to everyone if that's worth unbolting six bolts (per side), but it is a risk that can happen, and now everyone that has read this topic (or has read TIS) knows that and can decide his/her own actions.
BTW, I've broken that stabilizer link too (and that was by replacing a spring), luckily I had some lying around at the time (But I clearly remember I didn't have a spare driveshaft :roll: ).
But if someone complains that installing springs by a dealer or recommended shop is expensive, it's probably because they go and take that extra bit of security.
99% of the stupid and preventable accidents happen in independent garages, cutting corners
