Has anyone used an aftermarket front brake pad sensor ? do they work ok ? or would people recommend and genuine one ?
Cheers Nictrix, I'll pop along to my local car part supplier and pick one up and try it.Nictrix said:I have used Pagid sensors.
Not sure if they work completely as the pads are not used enough yet to trigger them.
Was able to reset the service interval though so are more than likely ok.
I did have a faulty Pagid sensor on my X6 though and it wouldn't let me reset the service interval, had to change it for another one.
1 for the front set and 1 for the rear.markplant said:Daft question does each corner have one as ecp sell them in one's
ThanksNictrix said:1 for the front set and 1 for the rear.markplant said:Daft question does each corner have one as ecp sell them in one's
Its probably done this way as under perfect circumstances all the front pads will wear at the same time so only one sensor is needed and same for the rears.markplant said:ThanksNictrix said:1 for the front set and 1 for the rear.markplant said:Daft question does each corner have one as ecp sell them in one's
This is the same thing that happened to my X6. I couldn't reset it and the garage couldn't either. Swapped the sensor and it reset first time.Jollyjoiner said:Well I put the new sensor on this morning and I still can't reset the service light. Took it to my mates and he plugged his snap on reader in to the car and that couldn't reset it either so it looks like I'll need to do some research into this to find out why.
Nictrix said:This is the same thing that happened to my X6. I couldn't reset it and the garage couldn't either. Swapped the sensor and it reset first time.Jollyjoiner said:Well I put the new sensor on this morning and I still can't reset the service light. Took it to my mates and he plugged his snap on reader in to the car and that couldn't reset it either so it looks like I'll need to do some research into this to find out why.
Chippie said:make sure the handbrake is off and your foot off the brake pedal
I think I'm with you on this one, what a pain in the arse,flybobbie said:Once i had fitted sensors and got them reset i tied them up out of the way. Couldn't be doing with the hassle i had the last time i changed them and trying to reset them.
I will use the good old fashioned Mk1 eye ball.
Lucky, i tried every combination, finally went to a indy that reset it for the cost of a couple of pints of beer.Chippie said:I had the same issue with mine it wouldn’t reset with either OBD port or with the stalk buttons, but with handbrake off and foot off brake they reset straight away
