MyOtherCarsA_UFO
I recently purchased a 2003 BMW Z4 3.0I Automatic knowing the brakes were not functioning properly. Here's the issue:
With the ignition turned to ACC, the brakes function perfectly. In RUN the brakes stay on after one pedal application, but can be reset with turning the parking lamps on and off again. They can also be reset with the turn signal/high beam arm. With the engine on and running, the brakes will turn on with the first press of the brake pedal and then remain on after released. They cannot be reset using the previously mentioned methods. They only shut off after engine is shutdown.
Already replaced the brake switch at the pedal, no change. Shot the lighting fuses for unusual voltage and they seemed fine. I tried bleeding the brakes and that didnt help. Looking at the schematic it looks like it could be an issue with the ignition possibly, or the "light switch cluster" which I'm not entirely sure what or where that is. I'm pretty stumped on this and would appreciate any help. Thank you!
