Boot hinge springs
d3matt
 Oxfordshire, UK
Just noticed these springs on the boot hinge tonight. Is the one on the left side meant to be hooked onto the stud?
I assumed it should, so I put the loop of the spring onto the stud, then shut/opened the boot and it made a few loud creaks & cracks, then pinged off the stud.
The spring on the right hand side looks like this, so I assume its snapped.
Or are they meant to be as per the photos?
The left one is correct- it is to help pop the boot on unlock- I'm not sure off had on the drivers side one.
It wont stay on, the springs comes off the stud every time.
Can't see what's wrong though.
No, I meant it is correct not to be on the stud. It is correct as it is in the picture.
Ducklakeview said:
Mine has them on both sides.
Mike
That would explain why my boot lid doesn't spring open much when unlocked. It barely moves - not enough to get your fingers under the lip. I'll look at buying another spring.
Mine is the same - righthand side spring is broken
Are these available as a separate part?
Your best resource for parts is https://www.realoem.com/
It doesn't look like it is, would be worth giving Sopers or another parts department a call.
New question on an old thread. Has anyone found a reliable source for these springs? I don't even see them on the EOM replacement hinge images.
Just looking for one at the moment. Incidentally, it broke on the same side as the original poster (the right). I know, n=2, but wondering if there is a greater likelihood of breakage on that side.
K.
I have a set of complete and in good condition Rear Trunk hinges.for sale ..where you located…I could post …
Thanks, Umfaan. I am in the USA (Boston, Massachusetts). I am only needing the springs that help the boot pop up when released. The hinges themselves are fine.
I have the same question too. Anyone knows where i can grab a spring or two? One of them snapped quite some time ago. I have driven at times with the boot unlocked without even realizing it :rofl: (key press in my pocket i suppose)
