sw4nny said:Both mine and a friends e85 3.0 2003 and 2005 have had this problem .
They were both fixed by one person pressing down on bonnet and slightly bouncing it (flat hands careful not to dent bonnet)
whilst the other person pulls the release catch inside the car.
As stated in previous posts would certainly try this first.
Also as stated above ensure its greased once open![]()
Rich-hill said:markeg said:Have someone gently push on the bonnet as you pull the release. If that doesn't work, remove the grills to access the catch from below (gills are removed by gently pulling forward from the top corners) and push the catch over
Its fairly common and usually due to gunk around the release catch and the cable - make sure you clean around there fully afterwards with a degreaser and use some oil/grease (not WD40!) - I use a oil with graphite added.
I have popped the grills out, but unsure which bits to try and push and pull. I will see if I can get someone to give me a hand.
Only got the car yesterday, it's #185!
