Hi all,
I’m posting this partly to get some thoughts while I wait for a mechanic, but also to share my experience in case it helps someone else.
I’ve got a 2010 BMW Z4 E89 sDrive23i, which was running perfectly before today — no warning lights, no rough running, nothing.
Today I did an oil change and oil filter change using:
Now the behaviour is:
Key details:
In the meantime, has anyone experienced something similar on an N52 engine / Z4 E89? Possible causes I’m considering:
- TotalEnergies Quartz INEO MC3 5W-30
- MANN oil filter
- Initially put in about 6 litres of oil
- The car will start if I press the clutch
- But as soon as I release the clutch in neutral, the engine cuts out
- It won’t hold idle properly
- Removed the new filter
- Put the original oil filter and original O-ring back in
Key details:
- Car was perfectly fine before the oil change
- Issue started immediately after
- No obvious warning lights before it cuts out
- Starts, but won’t idle and stalls quickly
- Same behaviour even after reverting to original filter and O-ring
- Oil level slightly low (only 6L added initially)
- Oil filter housing / seating issue
- Oil pressure or VANOS-related issue after the change
- Something disconnected or disturbed during the job (MAF, vacuum hose, etc.)
