BMW Z4 E89 sDrive23i (2010) – Engine cutting out after oil & filter change
23siaod
New member
 London
Hi all,
I’m posting this partly to get some thoughts while I wait for a mechanic, but also to share my experience in case it helps someone else.
I’ve got a 2010 BMW Z4 E89 sDrive23i, which was running perfectly before today — no warning lights, no rough running, nothing.
Today I did an oil change and oil filter change using:
  • TotalEnergies Quartz INEO MC3 5W-30
  • MANN oil filter
  • Initially put in about 6 litres of oil
After finishing, I started the car and drove for about 30 seconds, then the engine cut out completely. I restarted it, but it began to choke/splutter and then stalled again.
Now the behaviour is:
  • The car will start if I press the clutch
  • But as soon as I release the clutch in neutral, the engine cuts out
  • It won’t hold idle properly
Because I thought it might be something to do with the filter installation, I’ve since:
  • Removed the new filter
  • Put the original oil filter and original O-ring back in
Unfortunately, the problem is still exactly the same.
Key details:
  • Car was perfectly fine before the oil change
  • Issue started immediately after
  • No obvious warning lights before it cuts out
  • Starts, but won’t idle and stalls quickly
  • Same behaviour even after reverting to original filter and O-ring
A mechanic is on the way now, so I’ll update once I know more.
In the meantime, has anyone experienced something similar on an N52 engine / Z4 E89? Possible causes I’m considering:
  • Oil level slightly low (only 6L added initially)
  • Oil filter housing / seating issue
  • Oil pressure or VANOS-related issue after the change
  • Something disconnected or disturbed during the job (MAF, vacuum hose, etc.)
Any ideas would be appreciated. I’ll report back once it’s diagnosed.
Disconnect the maf sensor i think it runs in a sort of basic mode.
See if it runs smoother.
Few things i had with car was cam cover was bowed and oil in spark plug hole 4.
Also had faulty ambient temp. sensor fail behind left wheel arch liner.
