A
Anonymous
Guest
I stumbled across ASD (BMW's synthetic generation of exhaust notes) when upgrading my audio on my E89 20i 2012 version with the 11 speaker, 7 (really 8) channel 676 hi-fi amp.
Basically, to combat the perceived 'dullness' of the 4 pot engines and to make the M series sound sexier, BMW started adding the ASD device to their cars.
Its now been fitted to almost all BMWs..Minis included.
It works by picking up the throttle position/ gear position/ revs/roadspeed /top up or down /sport or comfort and then generating a polyphonic sound that sounds like a super duper tuned car..various versions are used with the same hardware and just different 'tunes' for differing models..
It sits after the radio/muli media unis and before the amp..and injects the noise into the amp at a predertemined volume irrespective of whether the audio/mm unit is on and independent of the volume control..
I noticed a dramtic increase in its effects when I change the speakers /amp where I assume the ASD was boosted by the improved speaker response.
Due to the way its wired in, you can't simply discconect it as then the canbus signals for the other audio functions, radio, bongs, nav are defeated as well.
I bought a bypass cable from the US to get round the problem.
Several owner groups have stumbled across it, mostly deleteting its effects, with either a re-program or a bypass cable..
