Bluetooth dongle
AndyBeech said:
Do you know what exactly your iPod connector connects to? Is it straight into the back of your head unit as an Aux or is it a separate unit like mine that broadcasts a radio frequency which your head unit then tunes to?
If it’s the latter like mine, all you should need to do is find the radio frequency and it’ll work (mine is 88.7 FM as below), no voltage adapter or otherwise needed....
If it’s another such system then I can’t help I’m afraid.
Thanks AndyBeech. I think it connects straight into the headunit as aux so this probably explains why yours is working and mine not. Thanks for the info though that has helped to explain why.
Chris_D said:
I refer you to my earlier post.
Thanks Chris_D. You don't happen to have a link to the adapter you use do you? Searched for the name but can't find it. Guess it needs both 30pin female & male connections. Slowly moving in the right direction!
I don't fella. Sorry, it came with the car.
BT dongle I bought doesnt work without the voltage adapter in between.
I have factory fit Ipod connector cable fyi.
Ok, no problem. Mine's the factory fitted ipod connector too although mine is connected fromthe glovebox and I note yours seems to come from the cubby behind the seats.
I'll try and find one of these voltage adapter thingys!
TBH urs doesnt look factory even if it's connected to the back of ur head unit.
I'm assuming mine is connected to the BT module so there could be a difference in cable voltage. But that white cable of urs looks like a generic ipod connector yo ucan get anywhere. I have some bought from ebay.
Try this:
https://www.amazon.co.uk/LAYEN-i-CHARGE-converter-compatible-Convertor-Black/dp/B00BFXPBD2
It's got power and your connecting to it with your phone so it should work, how did it work when you connected an ipod to it? I presume you had music playing from an ipod ok when connected? Did you have to select aux from the head unit?
Try this:
I think it is factory fitted as it looks the same as one the ipod brochure that came with the car. Thanks for the link. It says...
Please note if you are using this adapter to create a Bluetooth solution for your Bose 1 dock please put this either of these ASIN's in to the search bar for the correct solution: ASIN: B00BM3UCRA or ASIN: B00E3WSAAS...
so guess as I'm looking to use bt may need one of these similar models. They don't make it easy :D
It was many years ago but my mate used to use his ipod using it. Just pretty much plug and play. Think you had to select the 3rd audio option on the player i.e. not radio/CD.
I'm pretty sure I may have connected my iPhone to it too but switched to android ages ago too.
I've had the car since 2011 and it was probably in the first year or so that I used it but haven't since.
Quite frustrating now. I know you can get bluetooth fm transmittors but as I have this tucked away in the glovebox I really want to get it working now.
Strange it if played music from an Ipod it should just play whatever goes to the bluetooth dongle but I guess it's more complicated than that, always is! Was lucky with mine it seems!
Voltage adapter arrived today so tried plugging this between the ipod cable and bt dongle but unfortunately it didn't solve the problem.
Really bamboozled. Phone pairs to the dongle and stops playing music through the phone speaker once paired, but nothing comes from the car speakers and the stereo screen says 'no magazine'.
I know the ipod cable is connected to the stereo as it gives power to the dongle so isn't a loose connection.
I may have to look at alternatives (bt adapter from ebay) that others have installed but was really hoping for a quick fix without having to remove the headunit or anything. Especially as I got my car phone bluetooth working the other day and already have the ipod cable in place.
If anyone has experienced a similar problem or knows the likely cause I would appreciate their comments. Thanks.
Sorry to hear. I really thought the voltage adapter would solve your issues.
Out of guilt for suggesting you purchase one I can only offer a bit of troubleshooting advice;
In situations like these where I'm not finding a solution I usually break the issue down into its' consituent parts to cancel out component failures.
That said, my next step would be to start testing for redundancy in the system.
Individual steps to try:
1. Do you have any other devices that you can test the current configuration with?
2. Remove the dongle and voltage adapter and test the ipod connector with a 30 pin ios device (ipod/phone/ipad). If that works then it's definitely the android phone/dongle interface.
3. Check the BT settings on your phone and de-select 'use for phone calls' and 'access to contacts' in the dongle device settings. May help.
4. Check your Android version and that the phone is Bluetooth 4.1 or higher and that the dongle is also BT 4.1 or higher compatible.
5. If your existing ipod cable is USB at the head unit try a different USB/30pin cable.
Other than that, I'd be looking for an old ipod to use if the cable actually works.
No problem Chris_D the supplier offers a 30-day money back guarantee so it only cost a few £ for return costs. It was definitely worth trying.
Regarding the troubleshooting. I'm going to get my brother to try his iphone and will definitely try some of the other troubleshooting tips you give. :thumbsup:
Will provide an update if I manage to get it working!
Suggest you keep hold of the voltage adapter just for now until you cancel out the issues... you still might need it.
Oh yeah will definitely keep it until I've gone through all the troubleshooting tips. Hopefully I can isolate the issue.
