Bluetooth dongle
GJ1
Hello
I have a 30-pin old style i-pod connection in the glovebox and would like to plug in a bluetooth dongle to connect to my phone to play music.
I have an android phone.
Does anyone have any recommendations for dongles they have/do use using the 30-pin connection?
I'd put a BT adapter in if it were me. Straight into the back of the head unit, and gives you handsfree as well.
I'd still be interested to hear of dongle recommendations.
However, do you have any bt adapter recommendations? How easy is it to fit to the headunit? I don't have much experience of removing car pieces and always worry I'll create another issue.
Vin-decoder shows the car has S692A Preparation, mobile phone, Business and I have all the buttons on steering wheel and in cubby to suggest I have handsfree (I think) but I have never managed to get it to work!
Hi, this is the one I bought:
https://ebay.us/be6CMD
I'm not sure whether you have a cd-changer by your description, but this one utilises that function.
I had the same, old iPod connector in the glovebox that tunes to the radio. Think it’s a Denison or something.
Anyway, got this which is along the lines of what you mean I think:
Andoer® Bluetooth A2DP Music Audio 30 Pin Receiver Adapter Compatible with iPod iPhone iPad Speaker Dock https://www.amazon.co.uk/dp/B0118RTDK6/ref=cm_sw_r_cp_api_i_lgxtFb7GPVJT3
Works a treat, connect iPhone to Bluetooth dongle and then Spotify through the phone, sound quality is great, cheap and easy. Plug and play, no messing with wiring and CD changers.
The vin-decoder says Preparation, BMW 6-CD changer I-bus so I guess it would work if I went down this route?
This is what I had in mind but reading the description I'm not sure it would work with android phones.
Should be fine, if your phone connects to bluetooth then it’ll connect to this. If not, Amazon are good with refunds so you can probably try and refund.
OK, looks like you have 2 options to go with now. Certainly the Amazon unit is the cheapest, but I do you have the functionality of using the steering wheel controls? AndyBeech should be able to answer.
You'll need a voltage adapter that sits between the end of your ipod cable and bt dongle.
Using an mpow dongle here and USB AudioPlayer Pro on Android here. Works seamlessly.
Presumably you have to take the head unit out and fit this to the back? Is it easy to fit for a novice?
Is that so the battery doesn't drain or just to make it work?
AndyBeech do you use an adapter?
Nope no adapter, fits straight on to the ipod connector. Never had any issues and I use it all the time. No controls for the phone, you have to manually control it / skip tracks etc or just set up a playlist and go. It's a crude-ish solution but if you just want to play music from your phone and nothing else it works.
I'd say yes, but if you are willing to 'have a go', do some research on this forum and YouTube and continue to do what you're doing now, which is talking to forum members, then we'll talk you through it, or failing that, someone may offer to help. How familiar are you with working on cars? Also, where are you based?
Good to know if I go down this option. Maybe an interim solution :thumbsup:
I'll do some research :thumbsup:
My brother is pretty handy with cars so he should be able to help out. I'm based in near Gatwick.
OK. If you just follow some of the info here, you'll be fine. We're all here to help!
So plumped for this in the end. Got the white version but it's the same as shown in the link. It was recommended by AndyBeech.
https://www.amazon.co.uk/dp/B0118RTDK6/ ... tFb7GPVJT3
Unfortunately although it paired with my phone (as demonstrated by blue light on dongle & phone screen showing it paired) I couldn't get music to play through the stereo. I played music on my phone and it must have been sent to the device as no sound came from the phone but it was playing.
The stereo screen said 'no magazine'. CD and radio working fine.
Now I know many years ago the 30pin connection lead worked with an ipod. The light on the dongle presumably means the connection lead is still connected i.e. not come loose.
Anyone any ideas why the stereo may not be picking up the sound??
Do you know what exactly your iPod connector connects to? Is it straight into the back of your head unit as an Aux or is it a separate unit like mine that broadcasts a radio frequency which your head unit then tunes to?
If it’s the latter like mine, all you should need to do is find the radio frequency and it’ll work (mine is 88.7 FM as below), no voltage adapter or otherwise needed....
If it’s another such system then I can’t help I’m afraid.
